GSLB - Monitoring LTM VIP load balancing via iRule
In one of our environments we are configuring a single LTM VIP and load balancing multiple applications via an iRule. We currently have other LTM environments integrated via iQuery with our GTM for GSLB configuration and monitoring.
Is there a way to monitor the VIP at the GTM level via iQuery that would give a true back-end pool status? Since, let’s say, we are load balancing 100 different applications via a single VIP, if 99 of them went offline, the VIP would still show as ONLINE/GREEN.
Or would we even go as far as integrating via iQuery and adding a dependency monitor of the pool itself instead?
GTM serves DNSlayer that its dns response only contains ip addresses without any L4 port numbers.
in case the GTM pool member is LTM VS, then GTM response contains their VIP address (without the L4 port number).
as work around, you can make dummy LTM VS (using same VIP but different ports or different source address) containing monitors to each 100 applications, hence it will be marked Down if any of the monitor fails.
then bind this new LTM VS to the GTM pool, replacing the real (non dummy) LTM VS.
How is the LTM VIP green if you are using iRule to load balance, does it have a default pool which is green?
You should try configuring Prober Pools.
GSLB prober pools monitor health probes of the sync group servers to gather health and performance data about the sync group server resources.
All of the resources on your network are associated with a data center. BIG-IP DNS consolidates the paths and metrics data collected from the servers, virtual servers, and links in the data center. BIG-IP DNS uses that data to conduct load balancing and route client requests to the best-performing resource based on different factors.
DNS uses this data to optimize its load balancing decisions.
You can view the GSLB prober pools configured for the DNS sync groups you manage by going to Configuration > DNS > GSLB > Prober Pools From there, click a pool to edit it, or click Create to set up a new pool.
Benefits of F5 GSLB prober pools include:
  • Faster app routing
  • More efficient cloud scaling
  • Optimized cloud migration
  • Maximized app health, optimization, and protection
BIG-IP® DNS performs intelligent probing of your network resources to determine whether the resources are up or down. In some circumstances, for example, if your network contains firewalls, you might want to set up device-specific probing to specify which BIG-IP systems probe specific servers for health and performance data.
Prober selection and fallback options are available to provide a variety of monitoring choices for data centers and servers. Allowing the customization of prober selection for a particular environment may be useful in reducing false negatives due to network configuration issues and outages. The prober selection option specifies which BIG-IP system(s) are preferred when selecting a local prober. The prober fallback option controls what the BIG-IP system does when not enough probers of the type specified are available.
No default pool. We use an Address List for destination IP.
So the VIP itself is blue and not green, the GTM will report it as is because using iquery the system fetches the LTM virtual server status from the LTM without further monitoring.
You need to either implement some sort of monitoring on the LTM, but this is not be possible in your case unless you add a default pool (with monitoring enabled) to the VS, or to implement another type of monitoring except iquery on the GTM which will directly monitor the backend application.
That’s just it - the VIP is green - which makes me think that the either the Address List availability or a default pool listed in the iRule is available - but in evaluating the iRule, there is no default pool listed. So will have to dig more on how that VIP is showing as green. I’ve mentioned the direct monitor to the back-end servers, which renders the LTMs useless at that point.
