Get Started with F5 NGINX Plus, Ingress, App Protect and Management Suite
These free trials available for F5 NGINX Products will get you started on whats available and help you get certified.
Try NGINX Plus & NGINX App Protect
Try NGINX Ingress Controller with NGINX App Protect
Try NGINX Management Suite - NGINX
Helpful info, Kevin. Thank you!
Here are some more links that may help folks on the NGINX side of things:
In addition, we published the new Kubernetes learn page that provides an overview of Kubernetes and describes its terminology, concepts, architecture, and components. We also updated the Kubernetes glossary page.
Thanks  @Kevin_Davies  !!
