FTP and one leg setup - why not working
I tried to do setup like that:
VS in 192.168.1.1/24 network with IP 192.168.1.100 SNAT assigned 192.168.1.200 FTP server IP 192.168.1.110
Flow is then:
C → 192.168.1.100:21 ↔ 192.168.1.200:high_port → 192.168.1.110:21
Client connecting either passive or active is always refused, based on trace:
Passive - client attempt to connect to VS 192.168.1.100: to create data connection - VS is almost immediately sending RST to SYN packet. Backend server is reporting 425 Can’t open data connection for transfer of “/”
Active - as soon as backend server tries to create connection from port 20 to port passed by BIG-IP in PORT command BIG-IP is not responding to SYN, after 2 repeated SYN BIG-IP is sending RST-ACK, and backend server is again sending 425 Can’t open data connection for transfer of “/” over control connection
Same VS when accessed from another VLAN is working without issue in both Passive and Active mode.
Tested on both v11.2.0HF7 and 13.0.0HF2.
Am I missing something important that prevents FTP in one leg configuration?
Piotr
