How can we check what all failover methods have been configured in my organistion over LTM box. Is there any command for this ?
Failover methods are a configuration property of the traffic group as explained in the below article which applies to the 13.x release. If you’re not running the 13.x train yet, be sure to refer to the version of the document relevant to your environment. These device service clustering admin guides are your best resource on HA for each major release train.
You can find the associated failover method of the traffic group via the GUI as discussed in the referenced article under the heading of “Creating a Traffic Group”, via the below tmsh CLI command, or the equivalent API call:
list cm traffic-group *traffic_group_name* all-properties
You can find the traffic group name with:
