T0nyP
June 25, 2024, 12:05pm
1
Hi F5 Community,
We would to like ask if there’s a way in F5 thru TMSH command wherein we check or show all the default parameters or global variables set in F5?
Which we will export to a notepad or excel so that we can made a comparison from one existing system to a new one.
Thank you in advance who will be able to help us in our inquiry.
Hello Tony, usually the config-file will only display the non-standard entries when called with TMSH “list” command, but you can just input the “all-properties” keyword to show every parameter.
example: tmsh list ltm virtual <name> all-properties
T0nyP
June 27, 2024, 1:38am
3
Hi CA_Valli, thank you…is there a way to check as a whole appliance type or LTM module not only on the VS level?
I saw this URL cli global-settings
May I ask what is the correct command of tmsh for the list and all properties?
it’s “tmsh list all-properties”
for comparison purpose, simply generate the qkview then do the comparison in https://ihealth.f5.com/
T0nyP
June 27, 2024, 2:43am
5
Hi, I think BigDB Keys is the one. Is there a tmsh command as well to show all of this?
bigdb diff is mostly only timestamp of last config.
tmsh docs including downloadable pdf is available in
T0nyP
June 27, 2024, 3:51am
7
Ah ok. Thanks for the clarifications. Appreciate the reply.
