Facing issue with Https VIP on BIG-IP Kernel 4.5.14 Build5
Facing issue with https vip on version 4.5.14
All of a sudden one of our configured VIP :443 stopped working
Checked and found that there is no issue with reachablility to the actual server
Tried restart of the unit no luck
Run tcp dump test and found that the traffic is passing the big-ip unit
Require help on this
Hi Sumod,
You might try opening a case with F5 Support. 4.x isn’t supported anymore but you might be able to get “best effort” suggestions on troubleshooting this.
Aaron
