I found my solution in this thread:
Reprinted in case of link rot:
Installation
i1. download http://rapidshare.com/files/298983316/f5vpn-login-10.6.zip
i2. open a terminal window
i3. enter “cd $HOME/Downloads”
i4. enter “unzip -a f5vpn-login-10.6.zip”
i5. enter “cd f5vpn-login/bin”
i6. enter “sudo ./install.sh”
i7. enter “exit” to close the terminal window.
First time usage
f1. open a terminal window
f2. enter “f5vpn-login john@myhost.com”, replace john with your username and myhost.com with your F5 host address
f3. answer the password question with password followed by your token PIN, e.g. “mypass123456”
Cancel established VPN connection
c1. switch to terminal window.
c2. press ctrl-c
c3. enter “exit” to close the terminal window
Next usages
n1. open a terminal window
n2. enter “f5vpn-login” - if you do not provide a username and host the last ones will be used
n3. answer the password question as explained in f3. However, you’ll be asked for the password only if your old session could not be reused.
Questions & Answers (FAQ)
q1. Are special non-alphanumeric characters in the password supported (e.g. percent sign)?
a1. No
q2. Installation worked, but “fvpn-login” says “command not found”
a2. if the files /usr/sbin/f5vpn-login.py and /usr/bin/f5vpn-login are ending with question mark (?) than you probably have not unzipped the file using the “-a” parameter (see Step i4).
