I have an Active-Active LTM Deployment. Virtual Servers ( and Virtual Addresses ) are split between two units. I am trying to use F5-SDK to update traffic group so that VS/VA will move between two units.
Vars
BigIP_IP = "10.10.100.100"
V_IP = "172.31.13.151:80"
New_TG = "/Common/traffic-group-2"
Connect
new_mgmt = ManagementRoot(BigIP_IP, username, password)
Load
v_a_info = new_mgmt.tm.ltm.virtual_address_s.load(name=V_IP, partition='Common')
Assign new TG
v_a_info.trafficGroup = New_TG
Update Virtual Address
v_a_info.modify(v_a_info.trafficGroup)
But getting this Error :
Traceback (most recent call last):
File "update-virtual-address-traffic-group.py", line 13, in
File "/usr/lib/python3.6/site-packages/f5/bigip/resource.py", line 655, in load
raise InvalidResource(error_message)
f5.sdk_exception.InvalidResource: Only Resources support 'load'.
Then found out that “Virtual Addresses” are “Collections” and I able to read them fine using below command and loop through all attributes of a Virtual Address:
v_a_info = new_mgmt.tm.ltm.virtual_address_s.get_collection()
But then questions comes up how to update an Attribute of a “Virtual Address” in a Collection and push it back to the LTM to implement the change
Versions
F5-SDK : 3.0.20
LTM : 12.1.2 HF2
I highly appreciate any help or link to resolve this issue
-Muhammad
