F5-SDK Get GTM Pool Server, Virtual Server, Unused Objects, and JSON Conversion for Data Processing
I am honored to be able to use the f5-sdk python compilation tool. I think it is great! Unfortunately, it is no longer supported for updates. Recently, when helping users process data, I wrote some python scripts to handle unused objects and output them in dictionary format. There will not be many updates later. If you are interested, you can update the code. f5-sdk.readthedocs.io
Some of the code is shown below. You can refer to the attachment!
It’s a great honor to study and discuss with you all!:innocent:
from f5.bigip import ManagementRoot
import json
from tqdm import tqdm
Author: Nathan'Asky
Date: 2025-03-14
Version: 1.0
Description: Read DNS Device ConfigInfo
class GTMVisualProcessing:
    def LoadAccount(self,HostName,User,Pass):
        try:
            ConnectMgmt = ManagementRoot(HostName,User,Pass)
            return ConnectMgmt
        except:
            return "Device link failed. Check network and device availability!"
    def GetWideipDic(self,ConnectMgmt,WideipsJsonPath):
        try:
            WideipData = []
            for WideipType in tqdm(['a_s', 'aaaas', 'cnames','mxs'],desc="Processing Wideip", unit="Member"):
                for wideip in getattr(ConnectMgmt.tm.gtm.wideips, WideipType).get_collection():
                    if '_meta_data' in wideip.raw:
                        del wideip.raw['_meta_data']
                    WideipData.append(wideip.raw)
            with open(WideipsJsonPath, 'a', encoding='utf-8') as WideipsJsonFile:
                json.dump(WideipData, WideipsJsonFile, ensure_ascii=False, indent=4)
            del WideipData
        except:
            return "Data acquisition is abnormal; check the network connection!"
    def GetPoolMemberDic(self,ConnectMgmt,PoolMemberJsonPath):
        try:
            PoolMemberData = []
            PoolTypeDic = {'a_s':'a','aaaas':'aaaa','cnames':'cname','mxs':'mx'}
            for PoolType in tqdm(PoolTypeDic.keys(), desc="Processing PoolMembers Types", unit="type"):
                for pool in getattr(ConnectMgmt.tm.gtm.pools,PoolType).get_collection():
                   for PoolMember in getattr(getattr(ConnectMgmt.tm.gtm.pools, PoolType), PoolTypeDic.get(PoolType)).load(name=pool.raw['name']).members_s.get_collection():
                        if '_meta_data' in PoolMember.raw:
                            del PoolMember.raw['_meta_data']
                        PoolMember.raw.update(PoolName=pool.raw['name'])
                        PoolMemberData.append(PoolMember.raw)
            with open(PoolMemberJsonPath, 'a', encoding='utf-8') as PoolMemberJsonFile:
                json.dump(PoolMemberData, PoolMemberJsonFile, ensure_ascii=False, indent=4)
            del PoolMemberData
        except:
    def GetPoolDic(self,ConnectMgmt,PoolJsonPath):
        try:
            PoolData = []
                    if '_meta_data' in pool.raw:
                        del pool.raw['_meta_data']
                    PoolData.append(pool.raw)
            with open(PoolJsonPath, 'a', encoding='utf-8') as PoolJsonFile:
                json.dump(PoolData, PoolJsonFile, ensure_ascii=False, indent=4)
            del PoolData
        except:
    def GetServerDic(self,ConnectMgmt,ServerJsonPath):
        try:
            ServerData = []
            for server in tqdm(ConnectMgmt.tm.gtm.servers.get_collection(),desc="Processing Server", unit="Member"):
                if '_meta_data' in server.raw:
                    del server.raw['_meta_data']
                ServerData.append(server.raw)
            with open(ServerJsonPath, 'a', encoding='utf-8') as ServerJsonFile:
                json.dump(ServerData, ServerJsonFile, ensure_ascii=False, indent=4)
            del ServerData
        except:
    def GetVirtualServerDic(self,ConnectMgmt,VirtualServerJsonPath):
        try:
            VirtualServerData = []
            for server in tqdm(ConnectMgmt.tm.gtm.servers.get_collection(),desc="Processing VirtualServer", unit="Member"):
                for VirtualServer in  ConnectMgmt.tm.gtm.servers.server.load(name=server.raw['name']).virtual_servers_s.get_collection():
                    if '_meta_data' in VirtualServer.raw:
                        del VirtualServer.raw['_meta_data']
                    VirtualServer.raw.update(ServerName=server.raw['name'])
                    VirtualServerData.append(VirtualServer.raw)
            with open(VirtualServerJsonPath, 'a', encoding='utf-8') as VirtualServerJsonFile:
                json.dump(VirtualServerData, VirtualServerJsonFile, ensure_ascii=False, indent=4)
            del VirtualServerData
        except:
    def GetMonitorDic(self,ConnectMgmt,MonitorJsonPath):
        try:
            MonitorData = []
            for MonitorType in tqdm(["bigips", "bigip_links", "externals", "firepass_s", "ftps", "gateway_icmps", "gtps", "https", "https_s", "imaps", "ldaps", "mssqls", "mysqls", "nntps", "oracles", "pop3s", "postgresqls", "radius_s", "radius_accountings", "real_servers", "scripteds", "sips", "smtps", "snmps", "snmp_links", "soaps", "tcps", "tcp_half_opens", "udps", "waps", "wmis"],desc="Processing Monitor Type", unit="type"):
                for Monitor in getattr(ConnectMgmt.tm.gtm.monitor,MonitorType).get_collection():
                    if '_meta_data' in Monitor.raw:
                        del Monitor.raw['_meta_data']
                    MonitorData.append(Monitor.raw)
            with open(MonitorJsonPath, 'a', encoding='utf-8') as MonitorJsonFile:
                json.dump(MonitorData, MonitorJsonFile, ensure_ascii=False, indent=4)
            del MonitorData
        except:
