Hello, we have an public host for example outlook.foo.bar.de/owa with a vaild certificate, the cert should hold the VIP and than we would like to access the internal backend system they provide outlook.test.local/owa, access has to be work without any certificate issues and the host should not change in the browser, the user should think he is on outlook.foo.bar.de/owa ! So I think we need in the client ssl profile the cert for outlook.foo.bar.de and in the server ssl profile the outlook.test.local correct ? But I think I need for that an iRule to change the host header, to mask the host in the browser and so on ? Is there a example iRule for such a scenario?
kind regards
Please check this myF5
It will Change HTTP host header from IP address to an FQDN using iRule.
Please let me if it’s your request or tell me any other example or details for the req
Hello, read my question again, why from IP address to an FQDN ? I have a VIP the VIP has in the DNS outlook.foo.bar.de with a vaild certificate, so the cert hold the VIP and in the backend we have the internal backend systems they provide outlook.test.local/owa, with a vaild cert, what I want to know is how should I configure an iRule so that the user always se inside the broweser just outlook.foo.bar.de/owa and not a redirect to outlook.test.local/owa !!! And is it correct that I have to configure ssl client profile with the cert outlook.foo.bar.de and the server ssl profile with outlook.test.local ? An example iRule would be great
