Hi , we are using an F5 DNS (v12.1.2) .
We are now getting request for doing a DNS loadbalalancing for 2 IP’s in seperate datacenters. (openshift setups)
Both IP’s are accessible via https but are running multiple instances on same port (so different uri’s on same IP) . So using a standard https monitor isn’t a solution in this case . https monitor will work but will not show status of individual services . And we need to known the status of individual instances.
I was thinking about defining seperate monitors for each url specified . But the problem is that monitoring pools or members is done based on IP address . And i would instead need to use the FQDN in the monitor .
i’m able to use a curl command “curl -kvX -H GET https://<dns-name>/checkService” & this works when i use the FQDN .Using IP doesn’t work .
Anybody an idea on how to use FQDN’s in monitor?
i also tested with external monitors from articles " https://devcentral.f5.com/s/articles/http-monitor-curl-basic-get" & " https://devcentral.f5.com/s/articles/https-sni-monitoring-how-to"
But i’m getting some weird results when using these on F5 DNS .i was able to define the tls-sni monitor but when checking logs from debug i saw it takes all the variables i defined , except the 'hostname" , where F5 DNS continued to use his own hostname. Resulting in a failure . But not really sure if these external monitors are designed for use on LTM only or also on DNS ?
