F5 Big IP resets the connection after receiving SynAck
Hello,
I’m trying to create a pool that includes two members listening on port HTTPS customized port 7000, I’m using https monitor but pool never comes up. they are working only with ICMP. After troubleshooting I found that F5 BIG-IP is sending tcp resets to the pool members.
PCAP summary:
F5 internal <------SYN---------> pool member
pool member <------SYNACK---------> F5 Internal
F5 internal <------RST---------> pool member
TCP RST Reason Logs:
BIGIP-1 err tmm1[18512]: 01230140:3: RST sent from 172.16.120.100:61333 to 10.50.60.170:7000, [0x286ee03:2392] No flow found for ACK
BIGIP-1 err tmm[18512]: 01230140:3: RST sent from 172.16.120.100:61333 to 10.50.60.170:7000, [0x28448cd:263] {peer} handshake timeout
BIGIP-1 err tmm2[18512]: 01230140:3: RST sent from 10.50.60.170:7000 to 172.16.120.100:2554, [0x28449e5:985] RST from BIG-IP internal Linux host
Any thoughts ?
Hello Msaad.
This could be caused by a bug:
I would also check that you are not reaching more than 65k connections for that internal IP.
Just in case, are you using a ‘tcp_half_open’ monitor?
Please, share some more info (release, monitor config, etc).
Regards,
Dario.
