Hi, does anyone has experience with ASM 12.0? I realize the traffic learning is different, but I wonder how good ASM 12.0 is compared with ASM 11.6? If I have choice to choose the version, which one do you recommend?
I found this release notes on 12.0: BIG-IP ASM 12.0.0
In v12.0 ASM has greatly improved both the automatic and the manual process, basically unifying between the two - allowing admins greater visibility into Automatic Policy Builder’s logic, with streamlined UI including real traffic samples and easy sorting and filtering of learning suggestions.
I heartily recommend 12.0.
