Exhausted IP subnet range
Hi Guys, need help…
We are using a particular subnet 10.20.30.0/26 to configure web applications on the load balancer as a VIP on the INSIDE VLAN. However, i am running out of IPs and need an additional subnet 10.10.10.x/24 to function the same role.
What needs to be done on the load balancer for it to accept traffic on the new subnet.
Are there necessary changes that needs to be done on the Switch.
Would appreciate if someone can share a step by step procedure.
If you just need the subnet purely for F5 VSs then just configure your routing in the network to route 10.10.10.x.24 via the INSIDE VLAN F5 Self-IP (floating for HA). Then just configure your VSs with the new IPs as normal.
