Design Topologies
Hi All,
Can you please explain all the design topologies that are supported or can be implemented with Load balances as I am aware of only mentioned below. Also if any blog on this would help a lot.
Like Direct Server return, One armed, two armed..
Thanks, Sagar
Hi Sagar, Load balancer might support many design topology but i have implemented these three method.
1. one-IP network topology
2. Layer 2 nPath routing
3. Layer 3 nPath routing
