In 11.4.1, does anyone know the syntax of the Ciphers field if we want to reorder the DEFAULT order? The DEFAULT order is RC4-SHA, AES128-SHA, AES256-SHA, DES-CBC3-SHA, AES128-SHA256, AES256-SHA256, ECDHE-RSA-AES128-CBC-SHA, ECDHE-RSA-AES256-CBC-SHA, ECDHE-RSA-DES-CBC3-SHA. What is the syntax if want to reorder to have RC4-SHA last and put the ECDHE suites first?
the syntax is like this:
ECDHE:AES256:AES128:DES:RC4+RSA
as for me it’s not a good idea to use weak ciphers like des* or rc4+rsa
Thanks Vitaliy. This is an example of the TMSH syntax we used to successfully modify the existing DEFAULT setting: modify ltm profile client-ssl www.test.com { ciphers ECDHE-RSA-AES256-CBC-SHA:ECDHE-RSA-AES128-CBC-SHA:ECDHE-RSA-DES-CBC3-SHA:AES256-SHA256:AES256-SHA:AES128-SHA256 }
