Decrypt TLSv2
Is there any option to decrypt TLSV2 traffic, using ssl dump or using key?
Do you mean TLS1.2? What are you trying to do?
Yes you can decrypt the data by specifying the path, Use SSLDUMP command,
ssldump -Aed -nr /var/tmp/yourpacketcapture.cap -k /config/filestore/files_d/Common_d/certificate_key_d/:Common:www.site.com.key_1
Possibility to decrypt traffic depends on ciphers used. If RSA key exchange is used it should be possible to decrypt, if DH is used or any other Forward Secrecy or Perfect Forward Secrecy cipher suites then it is not possible.
It is not possible as well to decrypt resumed session. Capture must contain full SSL Handshake.
Piotr
