Can I convert an internal data group to an external data group? The internal data group is referenced in 2 irules. If I cannot convert do I delete the internal group and create an external group with the same group name?
Hi David,
To answer your question with best of my knowledge,
- Can I convert an internal data group to an external data group?
The answer is NO. The internal data group is in the memory. The external is refernced on files.
- The internal data group is referenced in 2 irules. If I cannot convert do I delete the internal group and create an external group with the same group name?
Yes you have to delete the internal dgl (lets say : sample_externaldgl) first inorder to create with the same name in the external dgl (lets say : sample_externaldgl). Same DGL (sample_externaldgl) names cannot reside in the same partition, it would throw error that it already exists. And you cannot also just delete the internal dgl, as its already referenced in your 2 Irules.
Simple steps to create via CLI.
- vi /var/tmp/sample_externaldgl_file.txt
(save and quit)
- tmsh create sys file data-group sample_externaldgl_file separator “:=” source-path file:/var/tmp/sample_externaldgl_file.txt type string
- tmsh create ltm data-group external sample_externaldgl external-file-name sample_externaldgl_file
