Hello ,
Need some help Setting up F5 SSO Solution , in this scenario F5 to act as an Identity Provider.
Following the SSO document 404 Page not found | BIG-IP Documentation
Stuck at the point Configuring an access policy to provide authentication from the local IdP Willing to use Active Directory Authentication
Configuring an access policy to provide authentication from the local IdPConfigure an access policy so that this BIG-IP systems (as an IdP) can provide authentication for SAML service providers.
- On the Main tab, click Access Policy > Access Profiles. The Access Profiles List screen opens.
- In the Access Policy column, click the Edit link for the access profile you want to configure to launch the visual policy editor. The visual policy editor opens the access policy in a separate screen.
- Click the (+) sign anywhere in the access policy to add a new action item. An Add Item screen opens, listing Predefined Actions that are grouped by General Purpose, Authentication, and so on.
I do not see an EDIT option here at the Access Profiles , attached is the screen capture
Just wondering what i missed here… Any help is greatly appreciated..!!!
