Hi Can some one help me with command in TMSH for entering in var/tmp folder ?
Hi vvskaladhar,
Can you clarify what you’re trying to do? By default, tmsh doesn’t have direct access to the filesystem. If you’re in tmsh and have full shell access and want filesystem access you can use ‘run util bash’.
Aaron
