I am trying to figure out the correct command for disabling or removing http management access. I believe the following is correct but not sure. This is for version 9-10
b httpd allow “NONE”
Hi!
Have you tried this article?
/Patrik
Note that I don’t think this applies to the iControl SOAP and REST interfaces. If you want to disable everything you may need to consider shutting down the httpd and tomcat daemons on start-up.
If you don’t mind about the iControl stuff your suggestion is valid I would have thought. I’ve no option to test right now but using a tmsh command try this and see if there is a None option;
[tmsh] modify sys httpd allow replace-all-with ...
let me test it for you. ![]()
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) modify sys httpd allow none
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list sys httpd allow
sys httpd {
allow none
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list sys db service.httpd.allow
sys db service.httpd.allow {
value ""
sys httpd {
allow none
value ""
Thanks much for all your help
Thanks as always!
Thanks as always!
How to add multiple IP address range?
