Cisco ACI integration with F5 using EPG
I am trying to integrate Cisco ACI with F5 using EPG (unmanaged mode). I have couple of queries.
1) As this will not a full integration(Managed one) then how can I map my vCMP guest with Cisco ACI.
2) Can I create Tenant in order to integrate F5 with cisco ACI.
/Regards Amit Grover
The F5 and Cisco APIC integration based on the device package and iWorkflow is End Of Life.
The latest integration is based on the Cisco AppCenter named ‘F5 ACI ServiceCenter’.
Click here to view the Cisco ACI and F5 BIG-IP design guide which discusses the following topics:
  • SNAT or no SNAT
  • BIG-IP redundancy
  • Multi-tenancy
  • Tighter integration using F5 ACI ServiceCenter
Visit F5 and Cisco ACI Essentials - Design guide for a Single Pod APIC cluster - F5 Technical Articles - DevCentral - An F5 Technical Community to learn how to access a lab for hands on experience using the F5 ACI ServiceCenter
Cisco ACI and F5 BIG-IP Integration | F5 for updated information on the integration.
