change hostname using GUI
how to change hostname using GUI in LTM 12.1.2
Has the GUI changed that much from 11.6 ??? In 11.6 go to System → Platform
Keep in mind that this wont’ change the hostname in your device certificate.
After you logon to the F5 GUI
System > Platform > Host Name (filed that you can change it)
So it will change in both GUI and SSH
Login to the F5 device GUI via a browser (use administrator account to login). Once logged-in see the list of section on your left side. There follow the below
System > Platform
Once you select Platform a screen will open where you will see the Hostname field. Change it to the desired value and go down and click update.
