Cert Auth - Serial Number
When trying to setup a check for a cert via APM I get an error that my SN is invalid when trying to save. I have tried several different formats(spaces, no spaces, : , etc) Has anyone run into this before?
It looks like the online help needs to be updated regarding what this box is requiring. The best bet to get the serial number is to do a "sessiondump -allkeys | grep " while the session is active and see what the serial number appears to be in the session variables.
From my testing you cannot have any spaces and all letters need to be uppercase. The certificate on my client looks like this “16 68 93 2f 00 00 00 00 00 06” but the session variable looks like this after the APM validates the certificate “1668932F000000000006”. As you can see it removed the spaces and made the F uppercase.
I would suggest trying the cert serial number as shown above and hopefully that will fix the issue. I would also suggest opening a support case to have the documentation updated. You can reference this devcentral post when opening the case.
Regards,
Seth
