Can I get a code example showing:
ITCMGlobalLB.Wideip.add_pool_virtual_server
in perl (SDK 4.6.2)?
Lenny Brown
Lenny Brown
Here you go. I’ve hard coded in the values. For this method to work you need to make sure the following:
1. The Wideip already exists.
2. The Pool is created within the Wideip.
3. The Virtual Server is defined as a Server (BIG-IP, Host, 3-DNS, EDGE-FX, Router).
4. If you want dependencies, the depends array must point to valid defined servers as well.
With that being said, here is some code that will do the trick. You will get Error messages to the effect of ITCMGlobalLB::NotExist or ITCMGlobalLB::DuplicateEntry if you submit invalid parameters or a VS that is already defined in the Wip Pool.
Hope this helps!
-Joe
sub addWideipPoolVS()
Build up parameters
my $wideip_name = "mywip.foo.com";
my $pool_name = "web_servers";
my $vs_source = { addr => "123.123.123.1", port => "80" };
my $vs_trans = { addr => "10.10.10.1", port => "80" };
my $vs_depends = { addr => "192.168.11.149", port => "80" };
my $vs_ratio = 0;
my $vs_status = 0; ENABLE
my $vs_state = 0; STAT_BLUE
my $vsAttr =
source => $vs_source,
translated => $vs_trans,
depends => [$vs_depends],
ratio => $vs_ratio,
status => $vs_status,
state => $vs_state
$soapResponse = $Wideip->add_pool_virtual_server
SOAP::Data->name(wideip_name => $wideip_name),
SOAP::Data->name(pool_name => $pool_name),
SOAP::Data->name(vs => $vsAttr)
if ( $soapResponse->fault )
print $soapResponse->faultcode, " ", $soapResponse->faultstring, "\n";
else
print "Pool Virtual Server added successfully.\n";
