C# Polling Default Pool Connections
Problem this snippet solves:
This C# application will display the current connections for all of the default pools. There was found to be too much overhead when sending in the list of all pools, some of which were empty so this app strips out the virtual servers with non-defined default pools and batches up requests for statistics.
Code :
using System;
using System.Collections.Generic;
using System.Text;
using iControl;
using System.Diagnostics;
namespace PRVD.iControl.GetAllPoolCurrentConnections
  class Program
    static void Main(string[] args)
      if (args.Length < 3 || string.IsNullOrEmpty(args[0]) ||
          string.IsNullOrEmpty(args[1]) || string.IsNullOrEmpty(args[2]))
        Console.WriteLine(
          "Usage: f5GetAllPoolCurrentConnections [username] [password] [hostname or ip address] optional [partition]");
        return;
      string user = args[0];
      string pass = args[1];
      string ipAddress = args[2];
      string partition = "";
      if (args.Length > 3 && !string.IsNullOrEmpty(args[3]))
        partition = args[3];
      Interfaces m_interfaces = new Interfaces();
      m_interfaces.initialize(ipAddress, user, pass);
      //Check if inialized
      if (!m_interfaces.initialized)
        Environment.Exit(Environment.ExitCode);
      //Get the partition list to drop into PROD
      bool partitionFound = false;
      ManagementPartitionAuthZPartition[] partitionList = m_interfaces.ManagementPartition.get_partition_list();
      for (int i = 0; i < partitionList.Length; i++)
        Console.WriteLine("Partition found: {0}", partitionList[ i ].partition_name);
        if (partitionList[ i ].partition_name == partition)
          m_interfaces.ManagementPartition.set_active_partition(partitionList[ i ].partition_name);
          partitionFound = true;
      if (!partitionFound)
        Console.WriteLine("The partition '{0}' specified was not found.", partition);
        return;
      //Get all virtual servers
      string[] localVirtualServers = m_interfaces.LocalLBVirtualServer.get_list();
      //PrintInfo(localVirtualServers);
      //Get all the active default pools
      string[] localDefaultPools = m_interfaces.LocalLBVirtualServer.get_default_pool_name(localVirtualServers);
      //PrintInfo(localDefaultPools);
      //Get the pool stats
      LocalLBPoolPoolStatistics poolStats = new LocalLBPoolPoolStatistics();
      //Get the pool stat entries
      LocalLBPoolPoolStatisticEntry[] poolStatEntries;
      //Load the localDefaultPools into a List<string> object to prune and perform batch get_statistics with
      List<string> localDefaultPoolsList = RemoveNoNamePools(localDefaultPools);
      string[] poolBatch;
      int batchCount = 1;
      Stopwatch timer = new Stopwatch();
      timer.Start();
      //Break the statistics rquests into batchs of XX
      while(localDefaultPoolsList.Count > 0)
        if(localDefaultPoolsList.Count >= 10)
          poolBatch = localDefaultPoolsList.GetRange(localDefaultPoolsList.Count - 10, 10).ToArray();
          localDefaultPoolsList.RemoveRange(localDefaultPoolsList.Count - 10, 10);
          poolStats = m_interfaces.LocalLBPool.get_statistics(poolBatch);
          poolStatEntries = poolStats.statistics;
          PrintStatistics(poolStatEntries);
        else
          poolBatch = localDefaultPoolsList.ToArray();
          localDefaultPoolsList.Clear();
        //Console.WriteLine("Batch {0} time elapsed: {1}", batchCount.ToString(), timer.Elapsed.ToString());
        batchCount++;
      Console.WriteLine("Total time elapsed: {1}", batchCount.ToString(), timer.Elapsed.ToString());
      timer.Stop();
    private static List<string> RemoveNoNamePools(string[] localDefaultPools)
      List<string> localDefaultPoolsList = new List<string>();
      foreach (string poolName in localDefaultPools)
        if (poolName != "")
          localDefaultPoolsList.Add(poolName);
      return localDefaultPoolsList;
    public static void PrintInfo(string[] info)
    for (int i = 0; i > info.Length; i++)
    Console.WriteLine(info[ i ].ToString());
    public static void PrintStatistics(LocalLBPoolPoolStatisticEntry[] poolStatEntries)
      //Loop through each pool and print out the server side current connection stats
      for (int i = 0; i < poolStatEntries.Length; i++)
        CommonStatistic[] commonStats = poolStatEntries[ i ].statistics;
        for (int x = 0; x < commonStats.Length; x++)
          if (commonStats[x].type == CommonStatisticType.STATISTIC_SERVER_SIDE_CURRENT_CONNECTIONS &&
              poolStatEntries[ i ].pool_name != "")
            Console.WriteLine("Pool name: {0}  Current connections: {1}", poolStatEntries[ i ].pool_name, commonStats[x].value.low.ToString());
}</string></string></string></string></string>
Thank you for this snippet but when I tried to run this code, and it get to the of getting the statistics “LocalLBPool.get_statistics(poolBatch)” it break and raise an exception “System.InvalidOperationException was unhandled” HResult=-2146233079 Message=There is an error in XML document (232, 79). Source=System.Xml do you know why?
