Hi I need some help to disbale ssl offloading to some IPs to t-shoot an issue. VS is configured with client & server side ssl profiles. But we want to bypass/disable ssl offloading both sides (client & server) for certian IPs to t-shoot an issue. How can this be done on a LTM running on version 15.x.
Hi ,
You should be able to achieve it using iRule. You can use SSL:: disable clientside or serverside commands. You can write iRule with the help of given examples here
