I am wondering if there is anyway to disallow the usage of POST using an ASM policy? It seems to be allowed by default with no way to uncheck?
Thanks, Dan
Thanks, Dan
If you need to disable POST globally (e.g. you have a virtual server only serving static content) then one way of doing this is via an iRule.
if {[HTTP::method] eq "POST"} {
reject
In ASM policy you can stop POST going through by setting the POST data length to 0 on the File Type and enabling blocking on “Illegal POST data length” violation.
Hope this helps,
Sam
Thanks Sam, it does help! ![]()
