If you are investigating the BIGIP server side connection, which ip address do you need to filter on tcpdump? Is it the SNAT-translated IP or the self-ip of the server side VLAN? Thanks!
Hello Joseph
For monitor traffic → myF5
For the client’s traffic, you use SNAT-Translated IP (only if you have configured SNAT, real client IP instead)
When you use Auto-map as SNAT criteria, that’s the rule of selection →
KR,
Dario.
