i’m facing a wierd issue on my F5 boxes, SYNC fails with this error (Local endpoint IP and Self IPs must be in the same subnet) error ID 01070734:3, did anyone face such issue?
Did you check both devices and ensure the network details for the network subnets are correct? If they are in order have you attempted to break and reconfigure config sync?
