BIGIP as Reverse Proxy
Hi all
Im trying to configure a virtual server to act as a reverse proxy so I can replace a TMG. It would proxy for some internal sites.
The goal is the following:
External Name: publicdomain.net Internal Name internaldomain.lan
-- https://publicdomain.net --> BIGIP --> https_or_http://internaldomain.lan --> WEBSERVER
I have followed this article: 404 Page not found | BIG-IP Documentation
I have configured a virtual server: - listening port 443 - no default pool - SNAT with automap enabled (to act as proxy, logically) - a client SSL profile (to make the client connect to the proxy via HTTPS) - a server SSL profile (to allow the BIGIP connect to the internal server via HTTPS - is this correct??)
But i have the following doubts: - How can i make BIGIP connect via HTTP instead of HTTPS to the internal webserver? - Is it neccesary the server SSL profile to make BIGIP connect via HTTPS to the internal webserver? But each site of the internal webservers has a different internal certificate. Really i dont know how to get this work.
Hope i have explained my doubts correctly
Thanks!
