Hello,
How can we confirm via command line or GUI whether REST Database is in sync between BIGIQ and BIGIP ?
BIGIQ: 5.4
BIGIP: 12.1.x
If REST database sync is broken between BIG-IP and BIG-IQ (suppose a change is done on BIGIP LTM itself ,instead of pushing it via BIG-IQ) , how can this be fixed and its impact ?
Mayank
Hi Mayank,
It took me awhile but I believe I have found an answer for you. Please see the following article. It has a section titled “Check the existing version of the installed REST framework” as well as a section titled “Manually upgrade the REST framework”. I believe that both of those sections should answer your questions.
K39741092: Manually upgrading the REST framework on the multi-blade VIPRION or vCMP system
-Nathan F
Thanks Nathan. Information given in the article is helpful. So Viprion hosts can also be discovered and managed along with guests via BIG-IQ.
