Hello DevCentral,
Is it possible to select the profile & enable the SSL::serverside in the iRule? In order to remove the SSL Serverside profile in the Virtual server configuration.
SSL::disable serverside (I want to remove the SSL Profile on the VS in order to remove this line)
switch -glob [HTTP::uri] {
"/xxx1*" {
SSL::enable serverside
ASM::disable
pool xxx1
log local0. "Pool Selected: xxx1"
"/xx2*" {
ASM::disable
pool xxx2
log local0. "Pool Selected: xxx2"
