'b verify load' equivalent?
Hello all,
this is probably an obvious question but i cannot for the life of me find a tmsh equivalent for the bigpipe command ‘b verify load’ - is there one?
Thanks in advance!
There is not. However, you can run it from tmsh:
run util bigpipe verify load
Thanks citizen_elah!
citizen_elah does indeed rock.
Don.
I tried “run util bigpipe verify load” after entering tmsh and I get an error as shown:
rallsopp@(Active)(/Common)(tmos) run util bigpipe verify load
Syntax Error: “bigpipe” unexpected argument
I also don’t see bigpipe in the list of commands when I tried “run util ?”
FYI - we are running version 11.0.0 Build 8037.0 with Hotfix 11.0.0-8131.0 applied on a BIG-IP 6400 platform.
Any insight/suggestions ? Thanks as always…
in V11, bigpipe is no longer supported. It’s still there, in a “hidden” location, but it’s limited in it’s functionality. I can’t remember the path, but you’ll find it with this command: find / -name bigpipe
Regards
Kurt Knochner
In v11 it is
tmsh load sys config … verify
