Hi
Has anybody done a pre-logon av check for microsoft forefront? Any info will be great…
Johan
Hi
Johan
Hi Johan,
Oo…yeah..sure have! What version of FirePass are you using? If you’re on 6.0.2 i would REALLY recommend you install the latest OPSWAT update before trying this. I had a few issues with MS ForeFront early on but the latest OPSWAT updates seem to work a treat and without any issue. ForeFront is listed in the drop down list of supported AV engines.
Cheers,
Mal
