Any one tried to sync ASM configuration between 2 data centers successfully? my current scenario is, i have HA pair (active/passive) in data center A and another HA pair (active/passive) in data center B and need to sync the the ASM configuration between the 2 data centers.
First you must have a connectivity between all BIGIPs.
Procedures:
Assume we have ( Device 1,2 in DC_A & Devices 3,4 in DC_B )
Reset device Trust for all devices.( because all devices must be under same trust domain , and in your current deployment now you have a trust domain in DC_A and another one in DC_B , so you must Reset it.)
Build Trust Relationship :
open BIGIP 1 >>> ( add Devices ( 2,3,4) in the Trust like this:
Go to Device Management >> Devices Tab >>> and review The ( Config sync , Failover ) for each device or configure them properly for each device ( For example you need to add a config-sync IP that can be reached from all BIGIPs to be able to do SYNC )
After That, deploy your current scenario >> Go to Device Groups TAB and Configure the below :
In Device 1 " which is in DC_A "
Configure a Device Group ( SYNC-Failover ) type , Manual sync with incremental.
Move just only Devices (1,2) from available box to includes box like this:
Now, you returned and Kept your current scenario ( 2 Datacenters , each one has an HA pair ( Active/Standby ) ) Test your config Sync between pairs >> it should Work as expected, so that’s fine till now , in the next step the new configs which you want to implement.
Return to Device 1 and configure the below:
Configure new Device Group ( open Device management >> Device groups tab >> Click Create )
This Traffic Group will only be related to ASM Configs synchronizations, so configure it as follows:
Give a name , Type : Sync-only , Manual with Full Sync “you will change it to automatic after making the initial sync manually” , add all of the 4 devices >> move them from available to includes.
Go to ( Security Tab >> options >> Application Security > Synchronization > and choose the previous/newly device group that related to ASM Sync only, like that:
Go to overview (Device management >> Overview ) tab and make the initial sync manually.
After That, Return back to Device groups TAB and then open the ASM Device group policy , and change it from manually to automatic Sync with incremental if you want that, you can leave it manual if you require to do the manual sync with each change in ASM policies, so the ASM Device group will be like this:
Thank you for your reply. actually i tried it but still not working,
first when i reset the device Trust for all devices , all devices become active standalone.
i added devices 2,3 and 4 to the first device, but still i see it as not trusted with first device, it showing as disconnected (specially for 3 and 4), i tried to sync between the devices but still not connected . Also, when trying to access Device Management ›› Overview, it takes sometime to open and after sometime it is disconnect and i have to refresh the page to connect again. Kindly check the snapshot:
so, if possible to test it again with the same scenario as i have here which is , i have HA pair in site 1 and HA pair in site 2 and need to do the ASM sync.
thank you for your concern. Actually that what i did, i selected “Generate New Self-Signed Authority” but same issue. i changed the DC2 devices to be in same VLAN as DC1 (ConfigSync IPs for all the device are in same VLAN) and it worked fine, so i guess it is a problem of my Lab’s network which not allowing the traffic between the 2 VLANs in DC1 and DC2. i already spoked with my network admin and will check for the communication between the VLANs, an will keep you updated.
So sorry for late to reply as i had another engagement. Yes, it was a problem of the network, there was a problem in communication between the VLANs and once solved, it is working fine. thank you Mohamed for your support. one last thing here, as the setup at the customer site is production, we agreed that in DC1, we will break the HA and do the ASM sync between secondary device in DC1 and devices in DC2 and test the ASM sync. we will create another VLAN to be used in configsync which will be routed through the network and disable all the other VLANs on secondary device in DC1 (so there will be no duplicate once we break the HA).
First, if the idea of Syncing ASM configs meets your needs so please mark the first reply as an accepted solution to be valid for other deployments.
For VLAN :
the 4 devices should be reachable to each other for the config sync >> it’s mandatory.
if you create new VLAN for example ip subnet /28 >>> so the 4 devices should be within the same subnet and devices should be reachable for Config sync.
Or you can allow routing between HA VLANs in DR and Main DC …
we can’t make routing between HA VLANs as the HA VLANs are direct connection between the devices in every DC. we will create a new VLAN on secondary device in DC1 (main DC) after break the HA and disable all the VLANs in secondary device except the new VLAN (which will work as ConfigSync VLAN) then make the ASM sync between secondary device in DC1 and devices in DC2. So, at this point, we will have primary device in DC1 working as active and serving users and in same time we are testing the ASM sync between devices secondary in DC1 and devices in DC2.
For the Delay >> take a packet capture on HA Vlan/port, then trigger the HA Sync and see timestamps for HA sync configs between the two devices,
but this scenario shouldn’t make delay,
try to disable ASM Sync and let just LTM Sync group and check.
For BOT and DoS yes you’re right DoS and BOT don’t support Sync-only device group it just L7 AWAF Policies, so you need Sync-Failover for DoS and BoT Defense profiles
When choosing the Local Address to use for ConfigSync, can I use a separate subnet between DC A and DC B? For example, in DC A, I use subnet 192.168.1.0/24, and in DC B, I use subnet 192.168.2.0/24 to ensure these addresses are reachable via routing. The firewall policy just needs to allow port 4353, right?
So you configure HA but with different subnets, Look I haven’t tried this approach before but the most important thing is to validate there is a reachability between the HA Pair ( TWO Devices ).
