I have nodes listening on port 80, 81, 82, 83.
the port 80 is mandatory and at least one out of the other 3 ports is mandatory.
with manual configuration, I put the port 80 monitor at the node level and the other 3 ports at pool member level.
with AS3, the node level monitoring does not exist.
what are the other options given that all my deployments are based on AS3.
thanks.
OM
