In this case, the Pool-Member will inherit the DST port of the VS when forwarding to it. The VS could also be set to * All Services, which would allow you to setup a VS-many-to-many-Pool port mapping.
When working with such * All Services rule sets, then you have to keep in mind that the Health-Monitor wont know which port to monitor, so you have to specify a port at the Monitor-Level.
Only if you have specified a Port at your Pool-Member, the monitor will become able to inherit the Port of the Pool-Member via the default “* All services” option.
Ok Thank you, but this last sentence is my Problem, I think this has worked all the time, and with new pool not
But to be sure I set the Alias Port, otherwise I could use same Monitor for different Pools
@kgaigl If your pool member has a port defined then the health monitor will absolutely inherit the pool when it performs the health check. To me it sounds like you did not set the service port to a single port when creating the pool members. If you could provide a screenshot of the pool configuration we should be able to direct you further to resolve your issue. If you need to provide a redacted configuration that will work as long as it shows the port associated to the pool member and the health monitor configuration that you are using.
