Application slow with ASM
Application(OWA) seems to be disconnected while enabling ASM. Security profile is set to transparent mode. What could be the issue?
Did you use the correct OWA ASM policy template for your version? If yes then you need to contact F5 Support. If you built the policy yourself then the problem can be far more complex and depend on things like response signatures/Dataguard and other features which when enabled can slow down the application
