Application stopped working and started working after failover & then stopped working after some time in the failover device.
It was working smoothly before on same device F5 LTM.
Issue happened immediately.
VS IP==172.23.118.165
Backend server IP ==172.23.118.121
Is it just this particular virtual server that’s being affected? I would check for duplicate non-floating self IPs between the active and standby device and I would also maybe try forcing offline the standby device temporarily to see if this issue reoccurs.
