APM: SAML-SP Reverse Proxy
Hi all,
Is it possible to use the APM as a SAML-SP Reverse Proxy as described here: Single Sign-on to Web Applications Using the Reverse Proxy ?
For security reasons the customer don’t want to give full access to the App where the SAML-SP is located, he asked for the feature above to have some sort of a SAML-SP Reverse Proxy in front of the App.
As an alternative it would be an idea to have an ASM in front of the SAML-SP App which protects the Backend-App.
Has anyone done this already and is maybe sharing some config help?
Thank you for any information…
