Have set up APM for remote login to our company, and for the most part everything works just fine. For the “normal” user there is a combined RSA/Radius and AD authentication process to get the two-factor authentication.
The problem that I have now is login for some partners and support organizations. As they do not have AD accounts I can not assign resources based on AD groups. I need to match the radius class (i believe it is class 25) to assign resources. This is done in the current remote access solution that is in place right now (pulse secure), but I can’t get my head around it in APM.
As I understand it it should be located in the variable: session.radius.last.attr.class But I can’t make anything of the hex string presented there… I have set up a test account in radius that has the class set to “F5-Test”, but I am unable to find this anywhere.
Any ideas on how this is done in APM, if it is even possible to do???
//A
