APM - OTP - HTTP AUTH - Hidden Forms Parameters
Working on Version 11.3 Latest Release and utilizing APM with an Access Policy, trying to get OTP to work with SMS.
How does one translate the required parameters presented in an example by the vendor into the variables needed to be pulled back to get OTP to work.
I can get the CURL feature to function from the BigIP Command Line, however I am unable to get the HTTP Auth Configuration to work.
I think my expertise falls under how to translate the vendor required attributes into the Hidden Forms Values. This is what I have and I get no response via the HTTP Auth I have setup. I have been unable to find a KB on something like this on Dev Central and feel this may help out any other person new to HTTP AUTH.
This is an example CURL - using the SMS OTP Verification using textbelt.com
$ curl -X POST https://textbelt.com/otp/generate \
       --data-urlencode phone='5557727420' \
       --data-urlencode userid='myuser@site.com' \
       -d key=example_otp_key
I can get this curl to work via command line when substituting my cell phone .
When I substitute my Phone Number to attempt a manual POST in the Hidden Form Value I get no results back.
In the Configuration for HTTP Auth -
Form Based > Selected
  Start URI > Empty
  Form Methd > POST
  Form Action > http://textbelt.com/otp/generate
  Form parameter for User Name > Empty
  Form Parameter for Password > Empty
  Hidden form Parameters/Values >
    phone='5557727420'
    message= 'Launch Code: $OTP!=%{session.otp.assigned.val}'
    lifetime=%{session.otp.assigned.ttl}
    key=example_otp_key
You must create a virtual server
  • destination : X.X.X.X:80
  • client ssl profile : None
  • server ssl profile : serverssl
  • pool : 1 member : textbelt.com port 443
then in HTTP server:
Start URI > Empty
Form Methd > POST
Form Action > http://X.X.X.X/otp/generate
    phone 5557727420
    userid myuser@site.com
    message Launch\ Code:\ $OTP!=%{session.otp.assigned.val}
    lifetime %{session.otp.assigned.ttl}
    key example_otp_key
