Hi all,
Just wondering if somebody did some APM Portal Webtop advanced customizing? E.g. a custom text on the Webtop page above the portal link icons? Which files need to be updated to achieve this?
Thanks a lot Regards Thrillseeker
Hi all,
Hello ThrillSeeker, we have a documentation discussing this topic : BIG-IP Access Policy Manager: Customization
ping back if you don’t find what you are looking for.
Finally, figured it out. version 12.1.2
What we wanted is to have banner/notice text on the webtop right after the header. If header.inc is customized, then the customization will show up in all different windows like logout.
File to modify: /var/sam/www/php_include/webtop/renderer/webtop_full/full/common/webtop_common.inc
Catch: apply access policy to take effect.
tmsh modify apm profile access [policy name] generation-action increment
K15176: Applying an updated BIG-IP APM access profile to the active configuration myF5
