I would like to reference a data group which has multiple strings and values, example.
Datagroup1
domain = "mydomain.com domain1 = "mydomain.com domain2 = "yourdoamin.com domain3 = "hisdomain.com
The logic should be something like below I’m just unsure of the syntax.
If domain data group contains “domain” Then set userdomain session.last.username set session.last.domin.
How can I sent the domain var based on the username’s value referencing the datagroups string value.
Hi Chris,
to use the class command (or any other iRule specific TCL syntax) within an APM policy evaluation, you have to use an iRule Policy Action within VPE.
VPE iRule Action:
- Name: DomainDataGroupCall
- ID: DomainDataGroupCall
iRule Code:
when ACCESS_POLICY_AGENT_EVENT {
if { [ACCESS::policy agent_id] eq "DomainDataGroupCall" } then {
set orig_domain [ACCESS::session data get "session.logon.last.domain"]
if { [set resolved_domain [class match -value $orig_domain equals DG_APM_DOMAIN_LOOKUP]] ne "" } then {
log local0.debug "Resolved Domain: $resolved_domain"
ACCESS::session data set "session.logon.last.domain" $resolved_domain
Cheers, Kai
