Need suggestion:- We have a ASM policy where response status code 403 is whitelisted. But while accessing the application F5 WAF is blocking the event/log with saying “Illegeal HTTP Status in Response” (403). Can i get suggestion on why this behavioral is observed.
By default F5 will not allow response code and if we allow this as per link it should allow . Can you check the logs and verify what error your getting. I hope you applied the policy after change and your waf is uptodate .
Hi, yes we have already establishhed the whitelisting while creating the policy and all changes are applied to policy. This issue is persistant for one particular URL and not the entire VS the policy is mapped to.
