I have an f5 cluster in front of a squid proxy cluster, and I want my squids to get the X-Forwarded-For header, which is not the case today.
My definition is as follows
ltm virtual /internal/webproxylb {
destination /internal/10.1.1.80:3128
ip-protocol tcp
mask 255.255.255.255
pool /internal/squidproxies
profiles {
/Common/fastL4 { }
source 0.0.0.0/0
source-address-translation {
type automap
translate-address enabled
translate-port enabled
vlans {
/internal/vlan5
vlans-enabled
I understand that as long as I am using FastL4 I cannot add X-Forwarded-For, but if I do try to remove it (I suspect it has been added to enhance performance, so I’ll have to take some care), will I be able to add X-Forwarded-For? That is, will the F5 recognize the
GET http://whatever.com/path HTTP/1.1
Host: whatever.com
as an HTTP request that it can add an X-Forwarded-For header to without changing anything else at all? All the examples I have found seem to relate to reverse proxying where the protocol is the plain
GET /path HTTP/1.1
Host: whatever.com
