Hi everyone, Please answer me a question and explain:
Is it possible to change to what URL it is forwarding on request to f5 depending on the user’s membership in the AD group?
Thanks!
Thanks!
possible with F5 APM module
Hi Petr,
Yes you can do It using APM following this steps:
You have to create a policy per session policy and of course a per request session in order to check each request (URI).
The per request policy let your analyse every user request…
Let me know if you need more details.
regards
Thanks, I will try
Thanks!
Hi, I have a problem.
When I add :
It’s OK! Authentication is successed.
But if I add
I get a message -
“AD module: query with ‘(sAMAccountName=userpod1)’ failed: Preauthentication failed, principal name: ldap_user@CORP.AVALIS.CO.UA. Invalid user credentials. (-1765328360)”
And I dont see {session.ad.last.attr.memberOf} in the REPORTS.
What do you think?
Thanks!
Hello, if the AD auth or AD query fails the session variable for memberOf will not be populated. In the AAA server object do you have an Administrator account configured? Are you sure the credentials for the user (or admin account in the AAA configuration) are correct?
Thank you, the Administrator account is configured incorrectly.
