02 - Visualization of F5 BIG-IP metrics on Grafana using Prometheus and Telemetry Streaming service
Configuration using CLI of F5 BIG-IP device
Following steps for the configuration of telemetry streaming consumer target using CLI of F5 BIG-IP device are discussed below:
Once you have accessed your F5 BIG-IP device CLI terminal then access either your default admin credentials or the new user you’ve recently created on the above section. Then execute the following commands on the terminal:
On the username and password section, you either enter your default admin credentials or the new user you’ve recently created has the administrator privilege.
curl -u username:password -k https://localhost/mgmt/shared/telemetry/declare
Note:
-k, --insecure
to be made secure by using the CA certificate bundle installed by default. This makes all connections considered “insecure” fail unless -k, --insecure is used.
ChangChange into tmp directory and create a file called ts-config.json and I am using vi editor for it.
cd /tmpvi ts-config.json
Paste the Telemetry Streaming declaration and then save the file and exit the vi editor.
{    "class": "Telemetry",    "My_Poller": {        "class": "Telemetry_System_Poller",        "interval": 0    },    "My_System": {        "class": "Telemetry_System",        "enable": "true",        "systemPoller": [            "My_Poller"        ]    },    "metrics": {        "class": "Telemetry_Pull_Consumer",        "type": "Prometheus",        "systemPoller": "My_Poller"    }}
Then execute the following command on the terminal on the same directory /tmp and change the username and password section with your F5 BIG-IP device credentials having the administrator privilege.
curl -X POST -u username:password -k https://localhost/mgmt/shared/telemetry/declare -d @ts-config.json -H “content-type:application/json”
To verify the available metrics
Section III: Configuration of Prometheus
Once the telemetry streaming service has been successfully configured and the metrics are available on the path. We need to configure Prometheus in order to scrape the metrics data on the predefined path. The following are the steps to configure the Prometheus:
Note: On this user-guide demonstration, both Grafana and Prometheus are installed on the same host with different service ports as mentioned earlier. CentOS 7 is used as the OS for this host machine and you may have different syntax to view the following status check.
First, check the status of the Prometheus
sudo systemctl status prometheus.service
View the current working directory and change into /etc/prometheus
pwdcd /etc/prometheusls -al
global:  scrape_interval: 10s scrape_configs:  - job_name: 'TelemetryStreaming'    scrape_timeout: 30s    scrape_interval: 30s    scheme: https     tls_config:     insecure_skip_verify: true     metrics_path: '/mgmt/shared/telemetry/pullconsumer/metrics'    basic_auth:     username: 'F5-BIG-IP-username'     password: 'F5-BIG-IP-password'    static_configs:      - targets: ['BIGIP-managementIP:443']
Then restart the Prometheus service and check the status of the Prometheus service.
sudo systemctl restart prometheus.servicesudo systemctl status prometheus.service
Note: If the configuration is correct, then the Prometheus service will be enabled otherwise, the status of the Prometheus service will be disabled.
To further verify whether instances has been discovered on the Prometheus:
-   Go to http://prometheus-ip:service/port
-   Click on the Status option and select the Target option
Section IV: Configuration on Grafana using Prometheus as a data source
In this section, we need to connect Prometheus as a data source on Grafana
Once the data source has been successfully configured on Grafna then Create a new dashboard and select Prometheus as the data source then select the relevant metrics and change the refresh interval as required. Save and apply the panel. Then, Save the dashboard and view the metrics on the Grafana dashboard.
The possible issue that can arise during the configuration
If you use the default TS declare from the official telemetry streaming document website then you may fail to view the available metrics on the mentioned link:
https://<f5-management-ip>/mgmt/shared/telemetry/pullconsumer/metrics
Hi Nishal! Thanks for these articles. Really looking forward to your presentation on our AnO/Modern Apps call.
Hello Victor,
Thank you for the opportunity to share my findings on AnO/Modern Apps call.
See you soon.
Thanks  @Nishal_Rai  - since this original content cannot be edited (over 24 hrs) after submission. We promoted your forum topic to a CrowdSRC article here: https://community.f5.com/t5/crowdsrc/02-visualization-of-f5-big-ip-metrics-on-grafana-using/ta-p/300642
You can edit that content, version controlled, if you find things need to be changed in the future.
To reduce confusion and conversation fragmentation I’ll lock this question and ask users comment on that article.
Thanks again! Great stuff!
Lief
