What are F5 Access and BIG-IP Edge Clients?
tl;dr - F5 Access and BIG-IP Edge are VPN clients that connect to APM access policies for L3 network connectivity.
Building on the DevCentral Basics article What is BIG-IP APM, a few quest...
Chase_Abbott
Admin
I do stuff.Chase_Abbott
Admin
8 years agoIf you use F5 Access, that is going to tunnel your connection to your site. You can split tunnel it or go full VPN tunnel. You would use either/or in this case. If you don't need a traditional VPN tunnel, go with a web-top and use granular app access.
I only use it when connecting to resources that are not available via webtop.
